I have (2) large hazmat storage lockers (8'X20') that need static grounding replaced after the grounding was damaged. The units are two feet apart and now are grounded with one (1) ground rod. My question is since these units have no electricity and are considered temporary, can I drive a ground rod for each unit or do they have to be tied together and use one ground rod.
I want to ground them seperately so if one is moved in the future. It is on a military base and I know if they move one they will disconnect both and not hook the other back up. Than you
