I went ahead and took an excerpt from that link above and extrapolated a theory
- U.S. fire departments respond each year to an estimated 25,900 home electrical fires. These fires cause an estimated 280 deaths, 1,125 injuries and $1.1 billion in property loss.
- Thirty-nine percent of home electrical fires involve outlets and receptacles, electrical branch circuits (for example, interior house wiring), and other electrical wiring.
Therefore, 39% of above would be
10,101 House Fires
109.2 Deaths
438.75 Injuries
0.429 Billion in Damages
Sounds like enough evidence to pass something like this to me?
The data is insufficient to tell us how many fires were caused by overheated receptacles.
The heat sensing receptacle will do nothing to stop fires from overheated extension cords or permanent wiring or overloaded circuits, which likely cause far more fires than anything happening at a receptacle inside a box.
The only time I have seen a receptacle actually get hot enough to catch fire it was used as a pass through. Pigtailing would have prevented the incident. The fire burnt through the side of the receptacle and smoke stained the wall above the cover, but no damage to the structure. When the receptacle burned, it melted a wire and shut the power downstream off.
On the same circuit I found one more receptacle that was getting hot enough to melt the plastic, but still worked. One screw terminal was loose, probably from years of thermal cycling. That was also used as a pass through ahead of where the space heater was plugged in.
A better code change would be to not allow receptacles to be used as pass through devices.
