Heat for thermograph image
jsw
williamsburg va
electrician / thermographer
Can you get heat from a mcc bucket with no load, like a bucket feeding a welding disconnect on but with nothing attached?
Welcome to the forum.
Unless you just turned it off, then immediately checked, why would any parts be warmer than any others?
Thus I would say not.
There could be heat from the busbar or adjacent buckets, but those sources should be pretty obvious in the image.
Thanks, I was thinking of a loose connection, like in the welding disconnect down stream.
I'm thinking wrong you have to have current to create heat.
