On my heat pump/ac unit the nameplate has a MCA of 15 amps and a Overcurrent protective device max fuse of 25 amps.Will 12/2 nm-b be ok to use to wire up to the 25 amp breaker?It is about a 15-20 ft run.
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
