I work for a low-voltage contractor that installs audio, video and home automation systems. My question centers on low-voltage cable used to trigger a turn-on switch in a gas fireplace. A little background forst:
Our client, who wants our automation system to turn on and off their gas fireplace (an insert in a brick fireplace), had their fireplace installation company install an ON/OFF switch. The switch has two connection contacts that, when shorted, turn on the fireplace. Our automation system has an internal relay that will short the contacts when the homeowner wants the fireplace turned on, and it will open the relay when the fireplace is turned off. The switch and electrical contacts on the switch sit inside of the fireplace some 8" from the open flame.
As I mentioned, my question centers on the wire used for this application. We commonly use CAT6 cable for low-current control signals. However, because the wire would be very close to the flame, and because of the higher than normal heat present at the switch location, is CAT6 cable suitable for this type of installation, or is there a high-temperature low-voltage wire/cable sommonly used for these types of applications?
Any help is appreciated.
