Atxrl1983
- Austin tx USA
Is it ok to heat shrink colored tubing on to a wire to change the color. After the heat shrink I typed up a label with all the wire characteristic and manufacturers information. Would this be ok for the nec.
It depends on the use, wiring method and color of the existing wire.
For instance we can change the color of a white conductor in a cable but we cannot change the color of a white conductor in a raceway.
I usually use tape to change colors and I have never written down the info on the wire I have covered up.
It also depends on the size. I think you can only remark above #6.
But the inspector may want to see the markings (at rough in?) to verify the wire type.I don't think that there is any code rule that says we cannot cover up the markings that the manufacturer is required to place on the conductors.
If so, will he trust your label?
