Dsg319
- West Virginia
- Wv Master “lectrician”
Going to test and see in the morning but figured somebody would know here. At a job there’s some heat trace we’ve installed and today had to go around with the the inspector and measure resistance values on the heat trace runs.
Wanted ohms readings from line to line on the heat trace and we got on the topic of wether the length of the heat trace would change the resistance (ohm reading).
Example, 75ft of 15watt per foot heat trace 120 vac. When measured resistance we got 4ohms. Say If we had double the amount would the reading change ? Never tested this theory before and wasn’t sure if it measured the the resistance of the whole run, or just at the point of contact.
