brother
where is this found in the NEC 2008 where 120volt heaters are limited by the electrical code to 1500 watts??
article said:In the above example of heater sizing, a 240 square foot room had a heat need of 2400 watts. If that were the room you were purchasing a heater for, you would have no choice other than to use a 240 volt heater, since 120 volt heaters are limited by the electrical code to 1500 watts.
