Customer wanted a motion / flood over the garage door. I hit the garage circuit installed a 240 deg hit from Home Depot. Did not work, the lights continually detected motion as if it were in test mode.
Returned it, picked up the 270 deg kit with 90W halogens.
Seemed to work okay. Next day, customer called and informed me the lights remained on all night.
Anyway, now I am way in the hole and frustrated.
I go to Heathco site and find this:
"INDUCTIVE PULL: Electrical devices that contain a coil will cause the light fixture to turn on without detecting motion if the device is on the same wiring circuit as the light fixture. Possible items that may trigger the fixture are: Ceiling fan, transformer, garage door opener, a fixture using a compact fluorescent (CFL) bulb (or any type of ?energy saving? bulb), overhead fluorescent lighting, or an electrical device using a coil plugged into a receptacle on the same circuit. If the device with the inductive pull is not removed from the same circuit as the light fixture, it will eventually lead to the failure of the sensor and the light will stay on all the time or start flashing on and off. Follow the steps below to determine if there is an inductive pull on the same circuit."
There is a gable end attic fan on this circuit, along with fluorescent, lights, freezer, garage door opener...............
Has anyone else experienced this?
I can't understand why a filter is not built into the detector, especially if this is a known issue.
Any thoughts if RAB motions are susceptible to this?
Thanks
Thanks
