dearbrummus
I'm a senior inspector in a large governmental agency. The NEC treats a heavy-up as a new service and my feeling is that when a contractor does a heavy-up he/she should install all new over current devices in the panel. They always install new cable, boxes, water ground clamps and ground rods yet they repeatedly install used breakers on a regular basis. Personally I believe this to be a mistake for a couple of reasons. First, the home owner is paying premium fees for the service and they deserve all new equipment. Secondly is from a liability standpoint. New devices will be covered in the event of a failure of the device and this helps tremendously in litigation. Used devices have unknown history and in the event of failure that result in property damage or physical harm the electrician as well as the inspector will be drawn into the investigation. As an inspector I don't want to sit before a judge and try to explain why I gave approval to the use of used devices that ultimately caused a catastrophe. Please give your thoughts on this subject.
