OK I a m still an apprentice so bear with me. I Have a question. I am wiring up a hot top and I am using 6-3 for the feed. My question is how do you wire up the disconnect if you are using 6-3? I bought a 60 amp non-fusible 3 wire disconnect. It has 4 lugs 2 os which are marked line. and of course the ground lugs. So I am going to have a total of 8 conductors in the disconnect, but I know where the grounds go. So I have 4 Hots and 2 Neuterals. Any help would be appreciated.
