Re: Help on Choosing a Truck
Mike we have one like these and the electrican that uses it loves it. But it does need a better way to haul your ladders.
As for the subject of which maker is better I would have to say GMC as we have all three and the Fords and Dodges dont hold up as well.
With Dodge it's the trany if you put them under to much load they will fail.
Fords we have had alot problems with the engines the 300 straight six is junk it gets worse gas milage than most V-8's 302's are not bad but no power.
If you do get a ford go desiel.
Also just a note on tires I started useing the Good Year Work Horse Extra Grip probely the best tire that I ever had for a work truck came across them just by accident as I bought a pickup with them on it and never got a flat had nails stick in them and just bend over so when I went to put tires on my van I read up on them and found that they have a nail guard steel belt that keeps the nails from going through and the milage is out of this world the pickup has 85,000 on these tires and the van has 58,000 on it and they still have a lot of tread left and for traction lets say I've been in to some deep sand and pulled right through and mud or snow.
they also make the same tire with a hiway tread that is not as griping but has all of the other features.
also they have a 8pr rating so they stand up to the heavy loads that I carry this was a big down fall with regular 4 pr tires as I was only getting about 15,000 to 20,000 out of a set.
and the price is not too bad if you can order them through a Sam's Club About $86.00 for 235-15 and about $106.00 for 31x12.50-15 or 265-16
If you want a tire that will hold up to nails give good traction and last a long time these are the ones
[ May 14, 2003, 10:23 PM: Message edited by: hurk27 ]
