hi
i need some help on this subject, the more i read the more confused i get, i'm getting different answers for the ahj's in my area.
here is the situation:
i have one new house where the homeowner wants the 400 amp CT can and meter base mounted on the outside of his pump house, from the CT can i will feed 2 200 amp main breaker panels mounted inside his house ( 75' away)and the pump house with a 60 amp main breaker panel, and he wants to also feed a shop in the future out of the CT can.
I was a little confused if i needed to group all of the disconnect. so i called the ahj, one said no, as long as everything is on the outside of the building you don't need to group the disconnect. then today i called and got another ahj and he said yes i would have to group the disconnect if there mounted on the outside of the building, but if i mounted the CT can & meter on a pole then i wouldn't have to group the disconnect. who's right
any insight would be greatly appreciated
