Help turning a porch light into an outlet...
inanium
New User
San Diego, CA, USA
Layman
Hi folks,
I need some help converting an existing porch light into an outdoor rated outlet. The existing porch light is attached to a round box in an exterior stucco wall.
My first thought is that I should break away the stucco, replace the round box with a proper outlet box, patch the stucco, and install an outdoor rated outlet + outlet cover. It would be nice to preserve the existing round box though, in case a future owner wants a standard light installed again.
Second thought was to use one of the sketchy, possibly not code compliant, adapters like the TayMac PRBA400G and put the outlet + outlet cover on that.
Another option would be to just attach a surface mount round box over the existing, in-wall outlet box and run a short piece of conduit over to a surface mount outlet box. I'm less thrilled about that due to aesthetics.
Any thoughts here? This seems like a common problem with more folks wanting things like string lights instead of traditional porch light fixtures.
I'll have to convert the whole circuit to GFCI most likely as I think I can't get away with installing an outdoor rated GFCI as it would be out of reach and require a step ladder to perform the routine testing.
What do y'all go with for exterior sealants? The box is under a large eave and well protected but I'd still like to seal it. 100% silicone or is there a decent option that's paintable?
Thanks for any help.
I am closing this thread, in accordance with the Forum’s rules.
This site is designed for:
Contractors
Electricians
Engineers
Inspectors
Instructors
This NEC Forum is for those in the electrical and related industries.
Forum rules prohibit us from assisting a person to perform or assist others to do electrical work who are not qualified. The reason is that the forum’s owner does not want a person to get an answer to the question they asked, but not get answers to the other questions they should have asked and were unaware they needed to ask. Mike Holt Enterprises and the Moderators of this Forum do not wish to place you and your family in danger, by allowing others to give you too little information to ensure that the installation is safe.
