physis
Re: Help with article 760
Will it be anyones fault if the smoke detector doesn't work because it is on a AFCI circuit that has tripped? Is that OK because everything's ok as long as it's in the NEC?
Edit: By the way I agree with you Bob.
Edit again: There's also a third possibilty in addition to:
AFI's do work, or
AFI's don't work.
Maybe AFI's knid of work.
And if that's true then basing their application on the assumtion that they either always work or they never work doesn't make any sense at all.
[ August 17, 2005, 02:46 PM: Message edited by: physis ]
That's the trouble with lawyers running the wolrld.IMHO any jurisdiction that allows smoke detectors in a dwelling bedroom to be installed on a non-afci protected circuit is exposing itself to a tremendous amount of liability.
AFI's do work, or
AFI's don't work.
