On systems the have a unit substation with a medium voltage primary and secondary voltages @ 480Y/277V-3PH-3W secondaries the main GFI protection they would utilize the N for the GFI correct? If GFI protection was also required on the feeders but all the feeders were 480V only utilizing step down transformers at the location of panelboards how would they provide GFI on the secondary breakers? How would this operate if there is no neutral to sum it to? Would it act like a delta and not operate on the first line to ground fault but trip on the second? Or would I have to provide a neutral to make the GFI operate?
