brantmacga
Señor Member
- Georgia
- Former Child
I'd like some input for a problem at my house.
I have a problem with lights flickering/dimming and voltage drops at small appliances.
When I moved in about 5 years ago, the house had a 150A service. I did a complete upgrade to a 200A; new meter & disco/panel outside, new 200A panel inside.
I spent some time measuring loads on circuits and getting my service as balanced as possible.
I've always had a slight voltage issue, but i think its getting worse.
I have an overhead-to-underground service. I've noticed that in storms or high winds, i'll get a severe voltage drop.
I'm thinking maybe there is a loose connection, possibly at the transformer. Its about 200 yds. away on a pole. Does this seem likely? I have checked and rechecked every lug and screw on my service and they're all tight. Or it could be possible my overhead drop size needs to be increased. I say that because when my heat was running over the winter, my voltage was slightly lower and i noticed a very slight flicker in the lights, and they were just a little dimmer.
Or another possibility; Once when I was checking lugs, I had a loose neutral in the disconnect outside. this was right after a storm and i was trying to trace a flicker. I wonder if its possible there is a loose neutral in the meter base?
its been slightly more noticeable today, and all my clocks in the house were flashing so at some point it was off during the day. i don't know if they were working on it upstream or what.
I've been wanting to call the POCO to come check things out, but I wanted to make sure i've covered everything on my end first. all the guys down there at the office know me and what i do. Should I just call them and see if they can figure it out? I think I've exhausted everything I know of on my end.
