Help with terminology
Twisted pairs and trios?
Sorry to bother again, but in the document I am translating it talks about shielded twisted pair cable and twisted trios (?) (groups of three conductors).
Twisted pair is obvioiusly common enough, but I have not heard of, nor can find in the Internet, a term for twisted groups of three conductors. Would anyone know what the correct term is please?
Tks a lot in advance.
Colin.
Colin.
Triads.
STWP
STT
More terms
More terms
I am back again to pick your collective brains if you don't mind :)
The text talks about distribution boards and how the cables enter them. It states that there shall be a bolted cover on either the top or bottom of the board, that it shall be made of nylon or "celeron" (that's my first question, I cannot find what celeron is in english) and that once the holes have been cut in these covers to allow cable access, the cables should be installed/fitted with "capas termocontr?teis" no longer than 10 mm (my second question is what these might be. "Capa" means sheath/sleeve/cover/jacket and "termocontr?teis" I believe is heat shrinkable). Would heat shrinkable sleeves make sense in the context of power cables and also LV cables?
Tks a lot,
C.
Help required
Help required
I posted a question some time ago (about terminology) but have seen no replies. Have I overstepped the mark and asked too often for help? Or should I post my question in another part of the forum?
Tks.
Tks a lot,
C.
Celeron is a registered tradename for Intel. I would use or "other approved material".
Heat shrink seems the appropriate translation. The installation seems somewhat strange. Are they using the heat shrink to prvide extra protection at the enrty holes for the cable against abrasion and and do not use standard cable glands? Or are those heat shrink connectors and they do not recognice cable glands as an approved mean? Seems curious though.
tallguy said:
BSP might be "black steel pipe", but it would be odd to have an English acronym in a Portuguese document.
BSP is British Standard Pipe thread, which is also a DIN and ISO standard and commonly used in Europe. Since this is conduit, and unqualified, they are probably talking about BSPP, which is parallel threaded. There is also a BSPT which is tapered pipe thread.
Help with a few terms please
Hello all again.
The document I am translating talks about the requirements for flexible conduit going through contraction joints in building walls and says that the conduit should be wrapped in "oakum" soaked in" tar" inside the contraction joint.
My question is whether oakum and tar (which is what the dictionary gives me) are indeed the terms actually used in the trade.
Thanks very much in advance.
Colin.
Colin Bowles said:
Hello all again.
Colin.
I believe that they mean "wrapped in tar soaked burlap".
Tks
Tks
Tks very much Laszlo. I had guessed "oakum" was a somewhat old term but couldn't think of "burlap".
Guess I owe you several beers if you are ever down this neck of the woods.
Colin.
Tks
Tks
Tks very much Laszlo. I had guessed was a somewhat old term but coudln't think of "burlap".
Colin.
Some more terminology
Hello again!
What would be the correct term for the option on a heavy duty battery charger used to charge a battery bank which literally translates as "drop diode unit"? Apparently the charger can come with or without this unit. Would it be "voltage dropping diode" or, if its function is to control/limit the voltage, a "voltage limiter diode"?
Tks again.
Colin Bowles said:
As far as the celeron goes, it seems to be a compound of phenolic resin and cotton (http://www.damari.com.br/celeron.htm and http://omen.en.alibaba.com/product/...Phenolic_Paper_Cotton_Laminated_Material.html )
but I cannot find a specific name for it. Certainly, Celeron is a trade name!!!
I found Celeron of the phenolic type on this website (with a little help from Google :smile:). Not much help in the info department but it might provide some insight for search expansion.
