I am a civil engineer by day and residential GC by night. Trying to make the transition to full time GC. I?ve grown up around construction all my life & this is what I?ve always wanted to do so I?ve been having a blast so far.
I?m trying to get up to speed on the NEC so that I?ll be able to check my electrical subs. I know that if there?s a problem & we fail inspection then he?ll be responsible to fix it, but I?d like to avoid that hassle if at all possible. I don?t ever expect to become an electrical expert, just looking for some help with the basics. So here are a few of the questions I have so far?
1. If he wires the house based on the 2005 NEC, but our local jurisdiction is still using the 1999 version, is that going to cause me any problems? Newer is better, right?
2. My electrician swears that wire nuts are not allowed when connecting the bare ground wires in the outlet boxes. He says the crimp on devices are required on the bare ground wires ?by code?. I didn?t see this in the NEC anywhere. I have no problem with him using them, other than they are a bit more expensive (I?m supplying materials...but it?s not enough to break the bank). I?m just looking for a little clarification.
3. I?ve asked him to run a separate circuit to each of the GFCI outlets in the master bath (one next to each of the double sinks). I figured this way no one would ever have to worry about tripping a breaker if there are 2 hair dryers, etc. running at the same time. Since the bath fan has to be GFCI protected, he has connected the fan to the load side of one of these outlets. I know my request was probably overkill to begin with, but does this defeat the purpose that I set out to achieve? Will a bath fan & hair dryer be enough to trip the breaker & cause problems? What about if you add a curling iron to that same outlet while the hair dryer & fan are running?
Thanks in advance for your help. Reading through all of these posts has already proven to be helpful.
