greggpratt
New member
My dad called today, he has a problem with his recessed cans. There are 8 of them. When turned on, the first 7 work correctly while the 8th on is dim. I am a journeyman in another state. I live 500 miles from him. I told him to change light bulb first. He did-still dim. It is still dim in the off position of the switch. So even when 7 are off the 8th is still dim. He used his meter. He has 40volts to ground even in the off position. I do not know how his house was wired. I believe it is a problem between the 7th to 8th can. Bad connection at 7 or 8. Scraped wire? Any ideas? Thanks
