ultramegabob
- Indiana
it is a PVC LB and if you look closely, the smurf tube extends above the form an inch or two, and the LB is attached to the pole with zip ties....
ultramegabob said:it is a PVC LB and if you look closely, the smurf tube extends above the form an inch or two, and the LB is attached to the pole with zip ties....
ultramegabob said:I will go back by tomorrow and see if they made any progress since I took the picture![]()
mdshunk said:There might be!
No, these things were used quite a bit in the late 70's and through the early 90's when a ducted system could not be easily and economically fitted, a traditional PTAC would be too small, and where multiple PTAC's could not be easily accomodated. These "trailer packs" have some pretty high heating and cooling BTU ratings, where one or two might do the job that would take 8 or 10 PTAC's. Nowadays, people are favoring mini-splits with multiple indoor evaporators, but these trailer packs are still the "right thing to do" in certain circumstances.
Always could, far as I know.donselectric said:since when were we allowed to use pvc fittings with smurf tube ??
kornbln said:how long is it safe to leave that ENT exposed to sun light? Carlon ENT isn't UV resistant...
