radiopet
- Spotsylvania, VA
Hey fella's..
I got this request on my board and quite frankly I am trying to figure out what they are asking and figured you all may have some comments on it also.
I gather he is trying to save money and be able to switch out his power to different meters BUT I dont think the use of the transfer switch is proper but I cant gather all they are asking...I have never ran into the request regarding this before....any thoughts
Most of the discussions involving transfer switches are related to using generators as the second source of power. I have a 400 rated service feed that has 2- 200 amp rated mains, separately metered. I want to install a manual "double throw" or transfer switch after these meters to allow either of these sources to supply a single load (200A) . Do you see any problems with this? I have looked at a Square D 82254 online- - - this type of box seems pricey, but maybe I am stuck with that . I did see a similar switch that did not have nuetral lugs-- - is there a way to make that work? It seems to me that I need a box that will have the nuetral switched along with the hots, is that correct? (I am confused where a panel without nuetral lugs would be used) My reason for doing this is to balance the energy bill. One meter sits idle while the entire monthly kw's used gets billed to the other meter. the cost here are "tiered" so the cost per kw goes up after a baseline allowance. If I switch which meter is reading the usage every 2 weeks, the cost per kw is reduced significantly. Any comments?
