dave121
- Central Wisconsin
We have a 1 ph. Dry type trans. 100 kva. Using it to step up from the power co.supplied 240v to 480 v. ( 240v to x taps, 480 out of h taps), Feed a VFD which runs a submersible 75hp. pump
480v 3 ph. load. The secondary amps are ok. The primary amps are too high. If we
Run the motor fast enough to pull say 100 amps. on the secondary of the trans. The primary
Amps are 300a. We install a lot of these, wire them the same and the amps are always, primary double the secondary. We have replaced the trans. and moved it further from the po. co's pad
mount trans. Neither change has helped. Other than wiring, any suggestions?
