High Bay 6 Lamp T8 Fixtures
KWH
I am installing these fixtures in a warehouse addition, with the factory installed disconnect inside the fixture are you still installing receptacles for easier maintence. I was going to wire these with a so/sj type cord, does this cord get sized based on the overcurrent device or can you reduce in size based on individual fixture load. I was reading thru some NEC 400 and not sure on the cord sizing.
TNBaer
Oregon
Plugs are great for maintenance. If you have a job of 100 fixtures, just sell them 101. Instead of changing ballasts in the air, just disconnect, hang the new fixture and do your maintenance on the ground.
