Ozymandias
- Missouri
May be the wrong time for this project.Bring your own TP,
Don’t forget the multihasp too if more than one person is in the gear!And WHILE you are working, you slide that tab up overt the Off button to keep it depressed, then put in your padlock. As long as that button is depressed, the switch cannot be re-closed.
Loud as an old Westinghouse when the spring recharges or louder?Bring your own TP, if you’ve never tripped it before. Same with cranking it back on. They make me jump every time.
Probably something that should be cycled more than once a decade.I have had a couple of them that din't fully open the contacts, they were stuck. Verify.
Usually find those during storm duty, old stores, and the switch had never been opened since it was first energized! Can’t hook the entire store up to generator, so the customer isn’t happy.I have had a couple of them that din't fully open the contacts, they were stuck. Verify.
Absolutely! I would also add padlock in the OFF position as Jraef stated.I have had a couple of them that din't fully open the contacts, they were stuck. Verify.
