I have a problem with a high resistance on grounding conductor.  the resistance is around 3 ohms. I know it is good enough to pass code but the client wishes it to be more around zero. He uses the equip for high end audio testing. All other recepts in the building are good. But the ones coming off a transformer to a panel upstairs are the ones being affected. Could the transformer be wired wrong( like the secondary Xo being hooked up to the equip ground?) would that cause the problem? I'm not sure how to help him at this point. Any suggestions?
