stickboy1375 said:
I'm doing a job now where whoever installed these boxes forgot to install the clamps.
A lot of the loom simply wasn't secured at the Gem box.If the concealed K&T was roughed in on porcelain knobs, and the distance into the Gem box is so short that the knob prevents the loom from pushing back out of the box. I see a lot of fished loom that isn't clamped. There were quicker materials than the Gem clamps, such as these wire clips:
electricman2 said:
Wonder what they would have done if they had to put a GFCI receptacle in it?
The old switches and receptacles, with their porcelain bodies, were every bit as bulky as a modern big bodied device (GFI or Dimmer). The installation technique was different.
One secured the conductors under the terminal screws after mounting the device to the box.
I pulled the switch out with the wires on in this photo above, for the photo only. If the box was still in the wall, the conductors would have to be removed from the terminal screws before the device could be pulled out as there wouldn't be any slack.
Also, most splices of conductor to conductor were done outside of the Gem boxes, occuring at the roughed in, or fished in, conductor runs.
