I have a combination starter inside of which is a separate 120 volt control circuit. The control circuit enters the enclosure and lands directly on a Hand-Off-Auto selector switch. The starter breaker disconnects the 480 volt motor circuit. Can the HOA serve as the disconnecting means for the control circuit or should another toggle switch be mounted outside the starter to disconnect power to the HOA? If the HOA is considered part of the controller then I think we need an additional toggle disconnect ahead of it?
