480sparky said:No, brownies are square.
makes sense to me. So, if I run 2 #14's then I have a #28 which means it's good for, wait let me look it up... hmmmmmm, maybe I should stick with a #10 afterall... :wink:mivey said:You're trying to pull some of that fancy math aren't you? Everybody knows 14 + 14 = 28. This ain't some of that pie are square stuff is it? Everybody knows pie are round. Cornbread are square.
pbeasley said:makes sense to me. So, if I run 2 #14's then I have a #28 which means it's good for, wait let me look it up... hmmmmmm, maybe I should stick with a #10 afterall... :wink:
You didn't get your secret 'lectrician decoder ring in the mail did you? With the secret ring, you can read the tables and get the hidden, correct data. I'm not even sure if I am supposed to tell you that so don't let on that you know about it, ok?pbeasley said:makes sense to me. So, if I run 2 #14's then I have a #28 which means it's good for, wait let me look it up... hmmmmmm, maybe I should stick with a #10 afterall... :wink:
It may be the same as a 10:480sparky said:No, the numbers get smaller when the wire gets larger, so two 14s make a 7, which is larger than a 10......![]()
I read this and hurt myself laughing. I'm confused now though. Do you add up or down?? Pluss no one told me about the ring.mivey said:You didn't get your secret 'lectrician decoder ring in the mail did you? With the secret ring, you can read the tables and get the hidden, correct data. I'm not even sure if I am supposed to tell you that so don't let on that you know about it, ok?It may be the same as a 10:
14+14 = 1+4+1+4 = 10
What ring? I don't know anything about a secret ring.iaov said:I read this and hurt myself laughing. I'm confused now though. Do you add up or down?? Pluss no one told me about the ring.![]()
I was gypped - mine only said something about drinking my ovaltine.mivey said:You didn't get your secret 'lectrician decoder ring in the mail did you?
buckofdurham said:[ Home Depot is paying beaucoup bucks to electrical tradesmen to work in their sores.
I got a phone call a while back from H.D., someone refered me to them and they offered me around 28 dollars an hour. I was surprised.[/QUOTE]Packinaglock said:They don't make much in the S.E.
$12-$19
jm1470 said:I see a violation if you are going to use the white for a switch leg you need to make it another color either with a marker or other means, not tape though, I fail for this in the past
dSilanskas said:While I was at home depot today take a look at what display they had. They are showing haha wiring 123
A carpenter acquaintance of mine went to work for a local lumber yard. He said pay and benefits was about the same and he doesn't have to crawl around on his now older knees so much. Its also a lot more comfortable working indoors than outside in the snow and rain and cold, and no more weeks and months long layoffs. I think the hourly rate was a little less, but working year round made it come out about the same.SPARKS40 said:Yeah...ha, ha, ha..got a friend of mine that has filled one of these "master trade specialist" positions at Home Depot.....$28.00/hour, 40 hours a week, and one of the best insurance packages i have ever seen, including medical, dental, vision, life, and 401k, all at a time where some of us are wondering where our next job may be coming from.
nc5p said:It is hard to believe a real tradesman would want to work there, unless retired.
stickboy1375 said:I'm a real tradesman, and if the money is there so am I, Its all about the money, end of story.
nc5p said:It is hard to believe a real tradesman would want to work there, unless retired. Stocking shelves, cutting wire, and trying to help clueless customers can't be very satisfying. Not like the satisfaction of a complex installation completed and working. I don't really recall running into anyone there who knew much. "I help in all departments" is a dead giveaway. Usually they struggle with properly identifying wire for cutting. Ask for #2 and they start measuring out #4.
