megloff11x
I would say that you need to inspect the system for damage. I used to make high-dollar instruments and we had a customer leave one under the sprinkler system. They sent it back, we dried & blew it out, cleaned it up, ran it through test & calibration, and charged them several hundred dollars for the trouble. The instrument was about 50-kilobucks.
Water doesn't conduct well. You have issues when teh radio falls in the tub because of salt from your sweat.
Likewise, floods aren't just water. It's fluid full of dirt and who knows what else.
It also helps start corrosion.
If it were me, I'd move out of the flood plane, or at least move the outlets above the likely flood level when the dry wall was replaced. Houses don't normally use waterproof construction material, so how many times before the structure begins to rot too?
Matt
Matt
