- Tennessee NEC:2017
- Semi-Retired Electrician
I didn't say they should pull a device out, just remove the cover.Pulling a switch or receptacle out of an outlet requires you to pull the device out, exposing you to wiring that could be come lose and require you to retighten a landing which they might not be "licensed" to do. Then the liability if the electrician says the HI messed it up when he pulled the switch/receptacle out.
