mkgrady
- Massachusetts
Dacron rope is good. Very low stretch. Polypropolene is also low stretch but not as strong so it needs to be bigger that you might think
Anyone made their own wire tugger? I need to pull a 415' run of 4 #2 and 1 #4.
Do you have the back story on that?
And yes i have made my own tugger and its safe ill post a picture if you like and many different ways to rigg pulleys and sheaves there you best friends !
What size conduit is it ?
No.2 s with a no.4 grd pull it with your help we did it years ago do some work its not that bad .
Or buy a greenlee tugger and work less but if its a one time deal run and you dont have the cash .
Put 4 or 5 men on a rope and start pulling thats not a heavy pull its just a long one dont forget to push it in the conduit that makes a bigg differance and soap it .
Option 2 rigg up a sheave run it thur a sheave that will increase you pulling force less men might only need three now .
Give more info and how many bends overhead underground give us more and well help ya .
This is an underground pull in 2inch sch 80 pvc. It has 2 90s, 1 approx 100-110 degree bend and some zigzags due to terrain that didn't need a heated bend.
Yeah I'd like to see a pic of your tugger
Did you use metallic 90's or at least one at the pulling end?
Roger
The trick is to use 36" radius elbows.
So a 1000 ft run with 4 short 90s pulls no harder than a 1000 ft run that essentialy turns in a circle ?
In the circle pull you have side wall pressure for the entire length, instead of just the distance of four sweeps.
I'm guessing the drill was a bit warm.From the time the drill was put on to the end of the pull was less than 1 hour.
By the looks of the rig - you could have easily pulled it by hand. Since the wood and the few screws in it would have self-desctructed otherwise.it actually did quite well and was not noticeably hot. Very powerful drill and was used in short burst the whole time to pull 12-24 inches pur tug.
