Re: home owner permit
" posted November 08, 2005 08:06 PM
Scott,
You found the missing bushing! There were no bushings anywhere.
George,
Good catch! None of them were stapled between the panel and the holes in the joists.
Also, there is only 3 conductors coming in from the disconnect at the meter!
Now what do we do about cable fill in these many different brands of connectors?
How do we call, 2 is max or 3 or 4? There is no way we are going to look for the brand and then look up the rating! "
Ok first site the code for the 1 missing bushing.It is plastic M A .Now just where else do you see a bushing maybe required ?
Now how are we to figure there is a disconnect from that picture ? Could just be a meter so no extra wire required.
As to how many permitted per connector !!!! well thats up to you to do the paper work.Your the inspector so either look it up or let it go.How can you right up what may or may not be a violation.Look it up or back off. GEE will that plastic MA cut into the wire and short it out.So far your score is zero.His might not be great work but site the violation that can stick.
