Bob Kraemer
- Ohio
Getting ready to make a wire cart out of strut and flat angle & right angle brackets. Just curious if anyone made there own wire cart and if you have any pictures to post?
Bob Kraemer said:Getting ready to make a wire cart out of strut and flat angle & right angle brackets. Just curious if anyone made there own wire cart and if you have any pictures to post?
Is that 10 to 15 reels that are each 2ft x 3ft???Tori said:. . . I have built a huge wire dispencer that would hold up to 10 to 15 reels - each 2 ft wide and 3 ft tall . . .
I like this one , when are you going into mass production ? This would be perfect for small jobs where you only need 8 or less spools with ya.480sparky said:I made several for a large commercial job using a $25 hand truck and two G-B wire dispensers ($20 each). They slip right into the hand truck.. no pins or bolts.
Not the best photo of it, but it's the only one I have:
Krim said:I like this one , when are you going into mass production ? This would be perfect for small jobs where you only need 8 or less spools with ya.
Carl
480sparky said:"Mass Production" starts when you go to the Big Orange store. :grin:
Krim said:So than,what did you do ... just slide 'em in place and spot weld 'em to the dollie ?
Carl
480sparky said:When push came to shove at a very remote job site, we took slats off of pallats so we could strap 1/2" EMT to them. Not pretty, and it was a pain in the arse to move, but it worked!
480sparky said:Nope, they just slid in. No weld, pins, bolts....
