mdshunk
- Right here.
The closest thing to making a wire rack I've ever done was just slipping some EMT between a stepladder or two.
e57 said:Ladders, milk crates yeah me too - than I got one of these:
It'll carry 8 #12.... or 4 10's
http://www.kremermfg.com/WIRE%20DISPENSER.htm Model 406
Then I split it in two - welded some angle iron on them to keep both halves stable so it was lighter to carry (one at a time) when full.
Okay, hit the local orange or blue store instead. :roll:jrannis said:Stolen Grocery Cart is a classic
ItsHot said:How about 2 painters and a piece of rigid!
480sparky said:Here's a last-ditch method, if you're really and truly desperate for a wire cart:
peter d said:Great idea! I'm going to have to make one of those now.![]()
Take a stick of 1/2" EMT, cut it into thirds (40" each).
Take two of the pieces and put back-to-back 90s on each end and install box connectors on the ends.
Now take two 4x4 (4", 4sqaures, 1900, 190, 189, 232, whatever you call them) boxes and remove 2KOs in each one on adjacent sides.
Put one bent EMT into one of the KOs, the other in the adjacent KO, and do the same at the other end with the other box.
When you set this on the ground, the two bent pieces of EMT will be at 90? to each other, and the box will be at a 45? in respect to the ground.
Now remove the center KO of the 'back' of the boxes, and push the third piece of pipe through.
Hopefully your imagination will work on this one.
Bob Kraemer said:
Thanks Chris,chris kennedy said:Pretty sweet Bob. How fast does it go?
Thanks 76nemo :grin:76nemo said:Looks nice Bob. Well built!
