Honeywell R841E
FrancisDoody
Durham, CT
R841E has two bi-metal switches. Can I bring two circuits into the relay. Hit a different switch for each circuit. Exit the relay to the loads. Or am I limited to one source feeding two loads. Thanks Fran
Well if you go by the instructions [110.3(B), IIRC], you're limited to one supply circuit. Disregarding that, doing what you want to do is possible. See Fig. 10 or 11 in instructions for internal schematic...
http://www.google.com/url?sa=t&rct=...=hULgNhIwpR3zo9NR6xIS-g&bvm=bv.42553238,d.dmQ
The striped leads appear to be a dry contact.
I just pulled the cut sheet on the White Rogers relay and that unit details two feeds to two loads
using two micro switches. Looks identical to the R841E.
