Chickens don't have long enough legs or distance between them for the same needs you get out of equipotential plane/equipotential bonding as is needed for larger four legged animals like cattle, horses, pigs, etc. Other items from 547 can still be similar like wet, damp, corrosive, mixed with feeds, bedding and other materials that can also add a dust component to the mix of things.
I will agree that some horse barns can almost fit into the cleanliness level or even higher than some homes that are occupied by some humans though.
If you have a concrete floor you pretty much need an equipotential plane to comply with NEC. I still seen many that don't have it and have little issues. Sort of comes down to some extent (reality wise) what you might have for electrical that comes fairly close to what the animals can come in contact with. Water tanks with electric heating elements are fairly common unless is an indoor location that never will get below freezing temperatures. Outside of dairy farms and maybe swine farrowing facilities (at least with types of places I have commonly encountered) often there is little else that is that close to the animals. Automatic feed systems usually have motors and such out of reach of animals (except for poultry but again they don't have same equipotential issues as large animals) and non conductive drop tubes and such.
