grainger said:What is the proper thing to do with the aluminum wire inside the cable? Also, is an anti-short required on this cable?
Type mcap is the type. It is supposed to be the newest typeiwire said:Which Cable?
Type AC or Type MCAP
iwire said:You can just cut the aluminum bonding strip and MC is not required to have anti shorts installed.
peter d said:I'll add that you can also cut off the bonding strip on type AC ("BX") cable as well.
iwire said:Yes, you sure can, but then you miss out on a good anti short holder.![]()
