finster1
- New Jersey
I am reading 5amps on the main waterline ground on a 240v service and I was called in because the cable guy said call an electrician. The cable for the tv was burnt and the cable guy was getting shocked. I lifted this ground wire off the main and you can see the lights flicker and a spark. I can read amperage with a clamp on but no voltage..I am thoroughly confused.There is also two meter pans on the house but only one service, the utility came and disconnected the meter and told the homeowner this was for an old program for the hot water heater which is electric...When you shut off the main the breaker for the hot water heater is backfed from this old meter but does not backfeedthe panel...I can clearly read 240v on the backfed breaker from the old meter pan after I shut off the main but it doesn't backfeed the panel anyone got any suggestions????The more load on the service the higher the watermeter ground wire reads....If I turn on additional devices it will read as high as 8 amps.Anyone got any suggestions? Ithough Ihad lost the neutral and the imbalanced load was bcause it was using the ground but, not the case...
