- Bremerton, Washington
- Master Electrician
I recieved the following from a technican at a city transportation department. I am hoping the forum users can help with an answer:
"We have ?hot poles? with a reported amperage of 32 amps going to the base. The supply voltage is 120 volts. The steel poles are not bonded and are fed with a 60 amp fuse.
We are looking for a method of quickly testing them without using a meter and grounding rod. Any suggestions?"
