brian john said:
I would be SUPER careful, accidentally back feeding the utility is a possibility.
I think the OP is asking how to test if the utilities are not hooked up at time of final.
If the utilities are hooked up then most areas will issue a temp. power release. This will allow the meter to be installed before final.
If the utilities are not hooked up I would normally connect a generator at the load side of the meter socket. With a 240 V generator it's easy to connect and check out the house. Unless you have a big generator you can't check out the AC units but you can make sure the wiring is good to the disconnect. It's safe enough because the generator has a breaker and if there are any shorts then the breaker on the generator will trip.
I don't have a big enough generator to power a range, water heater or AC units but I can take a meter and check for correct voltage at all disconnects and turn on all lights and check all receptacles. This lets you know that all wiring is good.
This is a common practice in many areas.
