olly
- Berthoud, Colorado
- Master Electrician
Would someone be so kind and point out where in 680 states the requirements for the disconnect for a Hot tub. I cannot believe I cant find it.
No I meant to reference 680.40 as that pulls in part I which pulls in 680.13I think you meant 680.41. However, that's not a disconnect, it's a motor stop switch. The disconnect removes power, the emergency stop only needs stop the pumps from running (in the case of something like hair entanglement). The emergency stop is not required for single-family residential use
680.13 specifically says "pool, spa, fountain or hot tub", so being pulled in by 680.40 was even redundant as far as this requirement is concerned.
