- Massachusetts
Perhaps the tub makers will get smart and offer an optional 3' deck of wood around the perimeter that would match the tub and comply with the NEC.
Cavie said:I see the 3' wood deck as the only option. My AHJ will never go for the cutting of the deck or toping with concrete.
jwelectric said:Check out what is coming to the 2008 cycle 680.26(B)(2) Perimeter Surfaces. For nonconductive pool shells, bonding at four points shall not be required.
Pierre C Belarge said:I do not know if the Draft is available online, but I picked up two of them at the IAI meeting.
Minuteman said:Pierre, you have a missing link.
ryan_618 said:I also agree that outdoor hottubs need the grid. 680.42(B) is very, very clear on this.
Pierre C Belarge said:Jim
You should tell them what went on in the UL meeting in regards to the wirenut issue.
Sounds like y'all need to start a new thread.volt102 said:Not too sure we should open up that can of worms. How about just posting a warning..."Do Not Use Red Wirenuts For Grounding and Bonding Purposes."
Jim
New Hampshire
