Re: Hot Tub install / replace main service / am I getting r
$1000 is reasonable. How far from your panel is the proposed location of the spa? Most local codes require the wires to be run in conduit from the panel to the GFCI disconnect and then to the tub. Make sure whatever electrician you chose gets a permit.
