Hot Tub Move - Disconnect / GFCI's
I'm in the process of moving our Hot Tub to a new location. The new location will not have a "line of sight" to the disconnect. Therefore, I have a plan to add an additional disconnect that will have a line of site.
Current Situation: AWG #4 wire is run from the main panel in my garage to my shed in the back yard. The panel in the shed contains a 50 amp GFCI. Then AWG #6 is run from the GFCI to the outside of the shed (Opposite side of the wall) to a 60 amp cutler hammer disconnect only box rated for outdoor use. This is in the line of site to the hot tub (About 35 feet of AWG #6).
In moving the hot tub to the new location, I will be adding about 40 feet of distance. I would like to add a second cutler hammer disconnect (Similiar to above) to the end of the current 35 feet of AWG #6 wire. I have a good place on the wall of the house that will be within "line of site" to the hot tub. I would then run an additional 40 feet of AWG #6 wire to the hot tub.
Is it ok to put both disconnects in series like this? Is the 75 feet of AWG #6 ok? Should I expect any GFCI tripping based on this change? I have never had any trips with the current configuration.
Thanks in advance!
Brian
I am closing this thread, in accordance with the Forum Rules.
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
* This NEC? Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
If you feel this action to be in error, feel free to contact me via PM to explain.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
