Riograndeelectric
- Lakewood Colorado
i recently rewired an existing hot tub and installed a GFI breaker previously it was non GFI protected. specs call out for a 40 amp circuit.
after I rewired and installed the GFI Breaker the hot tub started tripping the breaker when the heat was turned on. I ohmed it and also zeroed out the amp readings between all conductors and found there was some leakage of current. I advised customer to have heater replaced .
Heater has been replaced and still tripping the GFI when the heater is turned on.
I have not been back since the heater was replaced but was told by the owner that he had cal spa repair tech out and he can not figure out why the heater is tripping the GFI.. the hot tub was built in 1993. the owner bought the house some years back with the ho tub existing.
is there something I am missing or is there chance that the new heater element is defective.
any help would be appreciated.
Thanks.
Cameron
Thanks.
Cameron
