- Windsor, CO NEC: 2017
- Service Manager
Why is it that I can't find a code stating that Hot Tubs that are hard wired need to be GFI protected? I find receptacle types need GFI protection, but not hard-wired?
The code is not a product standard. It is an installation standard. Many hottubs have internal gfci protection or double insulation that would not necessitate the use of a gfci at the branch circuit or feeder.Originally posted by georgestolz:
Okay, we've got to follow listings, but if 100% of Hot Tubs require GFI in their listing, wouldn't the code have a word on it?
You are not missing anything, I agree with you. I was making a general statement that an assured ground is, in my opinion, better than a GFCI protected circuit.Charlie, the grounding system is independent of the GFI, isn't it? Adding a GFI doesn't compromise grounding. Or am I missing something?
