jeff48356
- Livonia, Michigan
I've seen those before in older houses. The proper term for the breaker that feeds the lower section is "Main lighting". A modern panel would have just a main breaker (not a main lighting one).Yes. They made "split bus" panels that had 12 slots for double pole breakers (usually the top as slots) and those 6 breakers were your service disconnect. One of these would feed the lower section of the bus and was typically a 50A or 60A breaker. Both houses I had with panels like that labeled the breaker feeding the lower bus as "main" even though it isn't really a single main.
