alsant
- villa park il.
do i contact the electric co for the new meter and feed upgrade or is this homeowner responsibility
			Seems like a very odd question.
Add it to your pricing thread and I am shaking my head.
How did you get a licence without knowing basics like this?
Here, too.Here the electrical inspector will fax the final "passing" inspection report over to the POCO.
220/221 said:Seems like a very odd question.
It's only the guy's 2nd post. The least you can do is let him get his feet wet a few times before wire brushing him.:roll:satcom said:He may of bought his license from Sears when they were running a sale!
It really does make you wonder.
Not to worry the inspection process, and the utility inspectors will make sure he gets his feet wet.
I think you're being a bit too condescending to the new guy. He's here for answers, not scolding.
Here, too.
Sounds like a commercial electrician who has been laid off and is trying his hand at resi work.
That may be, but even a commercial electrician has to work with the utility companies, Scott gave the best advice.
Depends on the size of the project ,alot of projects I worked the POCO had an engineer assigned to the job and he would contact you.But because each POCO is different the only sound advice would be to contact the POCO you are dealing with.
Yup, in new jersey, we need to notify the poco anytime we install, plan to install, or upgrade any service, and they also want the load calcs on new or upgrade services if there is any load change, then an assigned meter inspector/engineer will help you with the details, and inspection.
