Had a small electrical fire in the flooring of an unoccupied rental house. Happened about a week after the plumber cut a galvanized water pipe under the house. Upon inspection after the fire dept. removed the flooring in the area, I noticed there is a single cloth type #12 wire connected to a loose grounding clamp onto a galvanized pipe under the floor. A forensic PE investigator told me that if this wire is a neutral, or grounding conductor it could have a current running through it only, but no voltage after it passes through the load ??? I thought the two were always together :? I am going to trace this wire to it's origin, and terminate, and run a proper wire pair back to the panel bus, and also bond the galvanized pipe with a jumper, and clamps. Point to this post, can the neutral or ground carry current only with no voltage ?
